 Tidal - Amea Diacera - diamant diskant
HES Posted - 2014/09/22 : 01:03:43
Tidal Amea Diacera - stand højttaler i sort pianolak
Vejl pris er 160.000 DKK - NU 80.000 DKK afhentet (kan sendes mod tillæg).
Original emballage.
The Diacera variation on the Amea theme. Here, unwillingness to compromise is pushed to an extreme by making use of the 30mm diamond tweeter of the Sunray as well as its unique crossover technology.
With the customarily built stands, this is in every single aspect an unsurpassed stand-mount speaker without rival that we know of.
Specifikationer:
TIDAL-RMD-cabinet, 4° degrees inclination design
1 x 173 mm (7") Thiel & Partner (Accuton) woofer with white ceramic-diaphragm
1 x 30 mm (1,2") Thiel & Partner (Accuton) tweeter with black diamond-diaphragm
Passive crossover network with ultra low tolerance components, exclusive use of Supremecap-MKP-capacitors, metalfilm-resistors, massive copperband air-core-inductors, microphonically isolated x-over board
Extremly linear frequency response, excellent step response, optimised phase and group delay
Massive silver/goldplated soft-copper binding posts with removeable heads for fullsize-eylets, spades and banana's
Cabinet finish, high gloss polished piano lacquer: midnight black
Drivers: 1 x 30 mm tweeter, 1 x 173 mm woofer
Nominal power input: 100 / 250 VA
Nominal impedance: 6-8 Ohm
Frequency response: very linear, F3 = 42 Hz
Recommended amp input: We recommend quality instead quantity. Real 20 Watt at 8 Ohm are ok for normal listening levels (in rooms up to 25m²). It is most easy to drive and plays even at lowest levels "full and rich"
To use the whole dynamic range of it and listening complex music also from time to time very loud we recommend 100 watts at 8 ohm.
Efficiency: since several unrealistic numbers of competitors we don't want to confuse clients by comparing non-saying numbers on paper. Therefore we say with honesty: "Ordinary, good efficiency, nothing special in the good or in the bad way".
Dimensions: 47 cm x 22 cm x 33 cm
Weight: 83 Kg (pair incl. packaging)
