 M-audio Audiophile Firewire sänkt
hjort
Posted - 2013/07/30 :  10:41:26  Show Profile Send hjort a Private Message
Externt ljudkort med midi.
Drivrutiner för Win7 och mac:
http://m-audio.com/index.php?do=support&tab=driver
Nypris cirka 3.500:- säljes för 1.500:- 1.000:- 500:-
Kan även skicka med ett PCI Firewire kort med 3 portar om det skulle behövas.
Features
4 x 6 24-bit/96kHz I/O
2 x 4 analog operation (RCA)
Digital S/PDIF (coaxial) I/O w/ 2-channel PCM
Digital out also supports AC-3/DTS surround sound
Headphone output with dedicated level control
Flexible software-controlled mixing of hardware and software I/O
Aux sends on all channels and aux output assign allows for dedicated headphone mixes and sends to external effects
User-assignable front-panel level control (output, input, software return, aux send)
Zero-latency hardware direct monitoring
Low-latency ASIO software direct monitoring
Momentary switch for A/Bing two software-assignable headphone sources or switching ASIO monitoring on/off
1 x 1 16-channel MIDI I/O
Power on/off switch with indicator LED
Powered via FireWire bus* or included DC power supply
Two convenient high-bandwidth FireWire ports
Edited by - hjort on 2013/08/20 10:08:19
