 Kimber Kable 8TC *köpta*
Hotspur
fd. Fridefors
Posted - 2003/07/22 :  22:51:50  Show Profile Send Hotspur a Private Message
Kimber Kable 8TC
2*3 m, terminerad/lödd med Oehlbach: Två spadar i ena änden och fyra bananer i den andra, alltså slipper du bleck eller jumpers till dina biwire-terminaler.
Nypris ca 6000:-, säljes för 2700:- inkl. frakt!
Ring: 073-908 43 06 eller mejla: fridefors@hotmail.com
Oh, take it easy. I 'm not saying that there is no better cable or that there'll never be a better cable. All that I'm saying is that for now, my search is over. The TC allows a continuing and reliable amount of musical truth to emerge from every speaker that I listened to over the last six months. Other cables, many costing way more than the reasonably priced Kimber, have been on hand and none of them strike me as being more fundamentally true and neutral. This is a good thing, gentle reader. You can rest assured of two facts: You can afford Kimber 8TC. And, if you do choose to buy Kimber, no one on the block will own anything that beats it. Just go out and buy some!
Paul A. Cervantes
The Audio Obersvatory
Volume 2 Number 10 June 1994
Edited by - Hotspur on 2003/08/01 21:46:05
Jonas
Posted - 2003/07/23 :  17:26:38  Show Profile Send Jonas a Private Message
Får man fråga vad som hägrar bortom 1.3 SE??
"My head kissed the ground, I was half the way down"
Mina system
ekman
Posted - 2003/07/25 :  18:20:49  Show Profile Send ekman a Private Message
många frågor få svar =)
Hotspur
fd. Fridefors
Posted - 2003/07/28 :  11:13:35  Show Profile Send Hotspur a Private Message
Eftersom jag bestämt mig för att köra med QLN Splitfield (som har externt filter och äkta biwiring) så passar inte 8TC-termineringen. Just nu kör jag med 4*3 meter Supra Ply 3.4 men skall förstås hitta en kabel som bättre matchar Signaturernas klass vad det lider... :-)
doc
Posted - 2003/07/28 :  17:02:16  Show Profile Send doc a Private Message
Du har "Hotmail"
/doc
Burmäster
Fd. Dan
Posted - 2003/07/29 :  16:01:07  Show Profile  Visit Burmäster's Homepage Send Burmäster a Private Message
..och mail ifrån mig åxå
Artphotography
